Table 1. Fabric Extend - IPsec Compression product support
Feature
Product
Release introduced
IPsec compression
5320 Series
Not Supported
5420 Series
Not Supported
5520 Series
Not Supported
5720 Series
Fabric Engine 8.7
Supported on 5720-24MXW and 5720-48MXW
Supported using Fabric IPsec Gateway
7520 Series
Fabric Engine 8.10
7720 Series
Fabric Engine 8.10
VSP 4900 Series
VOSS 8.7
Supported on VSP4900-12MXU-12XE and VSP4900-24XE
VSP 7400 Series
VOSS 8.7
IPsec compression reduces the size of the IP datagram to improve the communication performance between hosts connected behind Backbone Edge Bridges (BEB).
Tip
Tip
As a best practice, use IPsec compression only for Fabric Extend tunnels where latency is greater than 70ms.
The following list identifies how you can implement IPsec compression:
To configure IPsec compression, see Configure IPsec Compression.
